Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Current per conductor in parallel › Reply To: Current per conductor in parallel
February 23, 2023 at 12:59 am
Hi Howard,
My model is for PCB winding with layers connected in parallel through vias. So each layer is an object but the vias connect them making them one conduction path. Ideally, the current per layer is equal to the current divided by the number of layers in parallel. However, we know, in real life, that there is difference in the current shared per layer. So the goal is to observe and measure the current shared per layer.
