Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › License issue – certificates › Reply To: License issue – certificates
matthew.buk
This is interesting.  Specifying the port from the Vendor line instead of the Server line seems to work perfectly. Thank you for that recommendation.
I did cross reference this information with the 2023 R1 Ansys_license_management_guide.pdf (page 38) section 'FlexNet Port Number'.  It suggests "The FlexNet port number may also be specified via the ANSYSLMD_LICENSE_FILE environment variable, if set".
For my sanity, using the FlexNet port number rather than the Ansyslmd port number is standard and your suggestion is a workaround for other potential issues, correct?   Hopefully making it clear will help others who may read this as well.
I greatly appreciate the help.  Thank you!
