Ansys Learning Forum Forums Discuss Simulation General Mechanical TARGE170 and arc line segments Reply To: TARGE170 and arc line segments
Rahul Kumbhar
Hi Ethan,
Can you give more clarification or APDL commands which you used? Why do you need TARGET170 element on the line? is it in contact with other 1d elements? Normally first you should generate mesh on line (probably beams?) and then define contacts.
