Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Message display ” Source setup is incorrect “ › Reply To: Message display ” Source setup is incorrect “
February 22, 2023 at 5:29 pm
HDLI
Hello Mahmoud.yehia,
Maxwell could find the terminals in one conduction path, and connect them through the default boundary.
Could you rotoate the coil with Band and inner Band? The inner Band would cover the coil and is smaller than Band, to make moving objects as one rigid assembly. Thanks.
Howard
