Ansys Learning Forum Forums Discuss Simulation LS Dyna Make a impact and measure the vibration Reply To: Make a impact and measure the vibration
peteroznewman
Yes, but you have to think about how the bat is supported.  It would be simple to have a ball impact a bat that is unsupported. The bat could have a forward inital linear and rotational velocity and that velocity would be slowed by the ball impact but also start spinning if the impact was any distance away from the bat center of mass. The bat would start vibrating.  If you modelled a pair of hands gripping the handle, the bat would not start spinning and the hands would absorb the vibration, damping it out more quickly than an unsupported bat, but hands would be much more difficult to model.  A mitigation to an unsupported bat spinning after impact would be to apply a distributed mass along the handle representing the mass of the hands. Add enough mass to put the center of mass at the ball impact point.
