Ansys Learning Forum Forums Discuss Simulation Fluids A B.C. that can specify both the normal velocity and species mass fraction Reply To: A B.C. that can specify both the normal velocity and species mass fraction
Essence
Normally, you should not get the backflow near the inlet. This happens due to incorrect case setup. Can you share the screenshot of the backflow near the inlet?
