Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid › Reply To: An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid
John Luke
It turned out that I had a simple mistake in the material assigment and when I gave the correct value for the young's modulus everything is behaving properly.
Thanks everyone for your help.
