Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Density of fluid affects the results and it makes the result wrong. › Reply To: Density of fluid affects the results and it makes the result wrong.
February 22, 2023 at 10:27 am
I can see how the flow is evolving at the restriction, that makes sense. The remainder of the flow field doesn't. How did you initialise the flow?
