Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Application of UMAT › Reply To: Application of UMAT
Pratik Ganorkar
Hi Andreas,
Thank you very much for the  response. I have learnt a lot from your advice.
The material erosion criteria I have been using is by UMAT. But it starts to give negative volume error, after adding CONTACT_EROSION_SURFACE_TO_SURFACE for all contact surface and taking high principle stress values in MAT_EROSION the entire plate gets deleted. What is the contact which I need to use to solve the problem.
The following image is of the elements gets deleted.
4 layer composite plate impacted by FSP
Thanking you
Pratik Ganorkar (pratik2116303@iitgoa.ac.in)
MTech Mechanical Engineering
Indian Institute of Technology Goa (2021-2023)
