Ansys Learning Forum Forums Discuss Simulation LS Dyna What theory or solution that ansys use for analysis the part damage? Reply To: What theory or solution that ansys use for analysis the part damage?
Armin Abedini
Hi Suwitcha,
In the Workbench, if you open the "Engineering Data", you can find out if a failure criterion has been assigned to your material.
Moreover, under the Toolbox menu, you can see a list of failure criteria that can be selected for your material. Note that no specific failure criterion is assumed by default.
