Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid › Reply To: An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid
erik.kostson
Hi
Can you check as it says the load might be wrong (and in combination with material properties) – try and solve for 0.0001 N.
All the best
Erik
