Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys Workbench 23 and 22 Licensing problem Reply To: Ansys Workbench 23 and 22 Licensing problem
George Karnos
Please make sure the port for the ansyslmd daemon is open on the license server firewall.  Starting with 2021R1 the applications must communicate through ansyslmd and lmgrd, where past releases used lmgrd and the ansysli_server process on 2325.
You can set ansyslmd to a static port by adding it in the license file on the VENDOR line.
For example:
VENDOR ansyslmd PORT=1056
