Ansys Learning Forum Forums Discuss Simulation General Mechanical An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid Reply To: An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid
John Luke
The handler is symmetrical in geometry and loads so I applied symmetry to simplify things, and I’ve tried fixed support instead of remote displacement the problem remains.
