Ansys Learning Forum Forums Discuss Simulation Fluids Contour with smooth color by Fluent Text Command Reply To: Contour with smooth color by Fluent Text Command
You may want to look at the /display/object options too: create the contours via the GUI and then display the persistent object. The workflow changed a few versions back, it's slightly more effort to set up but saves most of the panel options to make displaying easier.
