Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid › Reply To: An internal solution magnitude limit was exceeded. (Node Number 2174, Body Solid
Claudio Pedrazzi
Where is the remote displacement located in the model? please post a screenshot of it too.  It seems likely that you are not constraining enough, but I would like to judge after having seen the remote displacement.  Is this a shell model?
