Ansys Learning Forum Forums Discuss Simulation Fluids Warning in DPM Reply To: Warning in DPM
Check the injection. There was a change a few versions back so you need a small mass even if you don't have interaction with continuous phase switched on.  1e-20 kg/s is sufficient.
