Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to do steady state thermal simulation with only one boundary condition? › Reply To: How to do steady state thermal simulation with only one boundary condition?
ricardo
Hi Rahul,
Are you referring to this number?
I tried to simplify the boundary condition to test. I change the number so that the one facing the other radiating surface has the same number and the one that doesn't face anything have a different enclosure number. As you can see, the enclosure number of radiation B is "1", and radiation C is "2"
This is radiation B, where it faces each other. If I only simulate this without the other radiation, the simulation runs perfectly
However, once I include this radiation C, where it does not face any other radiating surface, the simulation won't run, even though I put a different enclosure number.
Am I understanding the enclosure number correctly?
Thanks
