Ansys Learning Forum Forums Discuss Simulation General Mechanical How to do steady state thermal simulation with only one boundary condition? Reply To: How to do steady state thermal simulation with only one boundary condition?
ricardo
Hi Rahul,
Tried your suggestions, and the simulations run but encountered an error
Tried looking for a solution to this similar problem:
/forum/forums/topic/problem-with-ansys-surface-to-surface-enclosure-type/
Turned out that the perfect enclosure can only be applied when the sum of the view factor is one. In this case, the inner surface does not have the "pair". Hence, the error happens.
I guess in the end I need to define the ambient temperature to make this simulation works
Thanks for your help
Ricardo
