Ansys Learning Forum Forums Discuss Simulation Fluids Fluid velocity in dpm_drag Reply To: Fluid velocity in dpm_drag
Chris_g
The working machine is a RedHat 8.7 compiled with the system compiler (as built-in is not available on linux).
The other machine is a Windows 10 using built-in compiler. On this machine I also occasionally get an error 126, which is solved after logging off and on again on the PC (I don't know if this is related).
