Ansys Learning Forum Forums Discuss Simulation Fluids Fluid velocity in dpm_drag Reply To: Fluid velocity in dpm_drag
Both with the same OS? Did you compile the code on both?  Fluent shouldn't fail like that, if solver failed to launch it's the installation, in theory cases & UDFs can't be machine dependent.
