Ansys Learning Forum Forums Discuss Simulation Fluids how can I obtain angular acceleration of the object in Fluent? Reply To: how can I obtain angular acceleration of the object in Fluent?
I suspect so. The surface forces and velocity are available, acceleration is a little more complex as it's the change in velocity. If you're using a UDF check for previous time step values, but note not all data is available.
