Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Density of fluid affects the results and it makes the result wrong. › Reply To: Density of fluid affects the results and it makes the result wrong.
What's the operating pressure? The only issue with the above is going to be keeping the solver stable as the gap opens. I assume the gap isn't closed to start with as that will mess with the solver schemes.
