Ansys Learning Forum › Forums › Discuss Simulation › Electronics › “process hf3d exited with code 149” on HPC › Reply To: “process hf3d exited with code 149” on HPC
Hello all,
How did you solve this problem ? I have Ansys electronics desktop 2022 R2 working on ubuntu 20.04 . I made my mesh pretty coarse and I have a lot of RAM and CPU power on my local machine and I still get this error. No matter I use direct solver or iterative solver I get the same issue. What is the solution for this problem ?
Here is the detail of the error that I get:
C_to_Sq_transition (/mnt/DD/ansys_electronics_projects/project_test/)
Transition_wr75 (Modal Network)
[error] Solving frequencies ... (Nondomain solver), process hf3d exited with code 149. (1:55:20 PM Jan 17, 2023)
[info] A discrete frequency sweep with 17 point(s) has been started using HFSS - Solving Distributed. (1:55:42 PM Jan 17, 2023)
[info] Discrete frequency sweep complete. (1:55:42 PM Jan 17, 2023)
[error] Sweep first_analysis_sweep_coarse failed (1:55:42 PM Jan 17, 2023)
[error] Simulation completed with execution error on server: Local Machine. (1:55:42 PM Jan 17, 2023)
