Ansys Learning Forum Forums Discuss Simulation General Mechanical Connection issue – Internal solution magnitude limit/Pivot error Reply To: Connection issue – Internal solution magnitude limit/Pivot error
ianyylai
Hi peter, I was under the impression that Normal Lagrange and MPC should be used where possible. Just some content I found online. It was said NL provides higher accuracy.
