Ansys Learning Forum Forums Discuss Simulation General Mechanical Change contact pressure visibility from contact to target body Reply To: Change contact pressure visibility from contact to target body
peteroznewman
Change the behavior from Program Controlled to Asymmetric. Then the Contact surface will be the one you defined and where the pressure is plotted. When set to Program Controlled, you allow the solver to flip Contact and Target at its discretion, and you don't want that.
