Ansys Learning Forum Forums Discuss Simulation General Mechanical Force reaction analysis Reply To: Force reaction analysis
jonl
You have to define either displacement or force, the other one will be the result of the simulation. If you get a higher force for the same displacement, this means your part is too stiff and you need to change the material properties.
