Ansys Learning Forum Forums Discuss Simulation Fluids Remove Constant Temperature Setting in Fluent Reply To: Remove Constant Temperature Setting in Fluent
DrAmine
I do not understand your case. Can you list the zones and the models you are using? If you go to flux report and do heat flux reporting: can you add the screenshot of the info printed into the Fluent console?
