Ansys Learning Forum Forums Discuss Simulation General Mechanical Changing young’s modulus in linear elastic 2D model Reply To: Changing young’s modulus in linear elastic 2D model
ali.ismail
I meant a 2D plane strain analysis. There is only one material under only the influence of self-weighing and defined by Poisson ratio, density, and young's modulus.
Horizontal displacements are not allowed on both sides and vertical displacement from the bottom is not allowed.
The dimensions of the model are 120*120 m and the diameter of the hole is 12 m.
And I am calculating the results only at 3 points shown in the mesh.
The geometry, mesh, and supports are shown in the pictures.
