Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Changing young’s modulus in linear elastic 2D model › Reply To: Changing young’s modulus in linear elastic 2D model
Please describe your model in more detail if you want a better answer. I want to see the geometry, mesh, loads, supports, and material definition.
What do you mean by 2D? Do you mean a 2D analysis such as Plane Stress or Plane Strain? Or do you mean you have planar surface in 3D? Show me a copy of the Geometry Details window to confirm.
A special case where you can change the displacement and the Young's modulus and have no change in stress is the following. A straight beam with an axial displacement of 1 mm. Double the displacement and halve the Young's modulus and you will get the same stress, assuming a linear solution.
