Ansys Learning Forum Forums Discuss Simulation General Mechanical Artefacts between contact surfaces in mechanical Reply To: Artefacts between contact surfaces in mechanical
LaraDlg
Hi Peter,
wow that's great! I think it might be the direct solver control that helped because it got rid of the singularities and penetration I had for system C.
Can you share with me the contact parameters that you ended up using? and did you keep linear elements?
Thank you so much,
Lara
