Ansys Learning Forum Forums Discuss Simulation Systems Convergence Issue Reply To: Convergence Issue
ashish.khemka
Hi Durga,
Can you please share snapshot of the solver output? In Mechanical generally when the default iteration value of 25 is exceeded then the solver exits the solution. If that is the case (you can check the cumulative iterations) then try increasing the iterations by using the command - NEQIT. For example - for specifying 100 iterations use NEQIT,100.
Ashish Khemka
