Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Determine Max Velocity within 2 inches of Surface › Reply To: Determine Max Velocity within 2 inches of Surface
September 22, 2022 at 9:54 am
Maximum something can be found in a cell zone with expressions, registers aren't available (yet). There is a cell-wall distance, but I suggest using it with care as it's also going to look for all of the walls.Â
Currently (2022R2) splitting the zone and reporting value via UDF is probably best if you also want the position.Â
