Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Reading Deck Syntax Error in element(Ansys Aqwa) › Reply To: Reading Deck Syntax Error in element(Ansys Aqwa)
ridoykarmoker1815
Dear Mike,
I've kept the line body and surface body in a single part. But, the results came same as a cylinder without morrison element. I'm sure that the result must change with the insert of morrison element. Can you give any idea about this?
