Ansys Learning Forum Forums Discuss Simulation General Mechanical How to use script to run the cfile for creating k file? Reply To: How to use script to run the cfile for creating k file?
igandiko
Which means ls-dyna not did not run. Check job_log.solver file to see if there is any output from sbatch command. What happens if you manually run job_command.solver located in ls-dyna/1.1? Are there any other log files from sbatch command?Â
