Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to use script to run the cfile for creating k file? › Reply To: How to use script to run the cfile for creating k file?
igandiko
Can you show screen shot of ls-opt workflow? Did you define file transfer operation between ls-opt and ls-dyna? If you did, check time stamps of when k was created in LSPP stage and compare it to time stamps of k file in ls-dyna stage and also time stamp of d3hsp file. This should give some clues.
