Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to use script to run the cfile for creating k file? › Reply To: How to use script to run the cfile for creating k file?
igandiko
Is this screen shot from job_log in ls-dyna stage? It says found matching criteria for error which means ls-opt found "E r r o r  t e r m i n a t i o n" line in d3hsp file so it looks like your ls-dyna run failed. Check ls-dyna messag/d3hsp files for errors.
