Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to use script to run the cfile for creating k file? › Reply To: How to use script to run the cfile for creating k file?
cct
In those following steps,
  1. There's a log file in stage1.1
  2. In the main directory, there's a kfile created from cfile
  3. The kfile doesn't show up in the stage of LSDYNA
It works now when I select "use queuing >simple" in the stage of LSPP, which seems the error occurs as you thought that LS-OPT is running sbatch command correctly by its not waiting for LSPP process to finish and moves on to LS-DYNA stage.
Thank you so much!
