Ansys Learning Forum Forums Discuss Simulation General Mechanical How to use script to run the cfile for creating k file? Reply To: How to use script to run the cfile for creating k file?
cct
The job_command.solver shows in stage1/1.1 as following
When we use run_lspp to create kfile from cfile, it works. Yet, when we use run_opt to submit the LS-OPT job, it jumps out the same error and kfile isn’t created.
