Ansys Learning Forum › Forums › Discuss Simulation › Fluids › EDEM-Fluent on batch mode (computers without GUI) › Reply To: EDEM-Fluent on batch mode (computers without GUI)
fatemeh.hosseini
You are right. When I wanted to run a CFD simulation I set all parameters in my computer and only run it on cluster. but now, I should use coupling tools and when EDEM and Fluent connect together, new features will apear in Fluent and should be set.
So I should set them after coupling in a Fluent TUI.
Most of the setting should be done in Fluent,So Fluent control the process.
Fatemeh
