Ansys Learning Forum › Forums › Discuss Simulation › Fluids › fluent setup method › Reply To: fluent setup method
Is the cylinder a metre diameter? The experiment is usually about 25mm (one inch). Check the other boundary conditions. How does the velocity field look?
