Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Will the flow from a room fan be laminar or turbulent? › Reply To: Will the flow from a room fan be laminar or turbulent?
ehsan.sadeghi
a simplest way would be measuring the flow rate in a fan rpm, then based on fan diameter and estimated mass flow rate you can calulate the reynolds number. it should give you a rough estimate of the flow regime.
