Ansys Learning Forum › Forums › Discuss Simulation › Photonics › INTERCONNECT not reasonable results › Reply To: INTERCONNECT not reasonable results
Guilin Sun
One of my colleague will check that post. I still suspect that the signal generation is random everytime you run it. If you fix the "seed", it should be the same:
