Ansys Learning Forum Forums Discuss Simulation General Mechanical How to use script to run the cfile for creating k file? Reply To: How to use script to run the cfile for creating k file?
cct
We tried the way entering /sw/hprc/sw/LS-PREPOST/4.8.9/lsprepost4.8_common/lsprepost in LSPP stage, but the key file is not created.
We tried editing the script and now it could create the key file from cfile when we submit the run_lspp file. However, even though the run_lspp file works, when we use sbatch ../../run_lspp in command in the LSPP stage, the stdout in LS-Dyna directory still shows the key file cannot be found.
We checked LsPrepostOpt.inp and it has the replacing parameter values.
