Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Model Marangoni effect – dependent on temperature and UDS › Reply To: Model Marangoni effect – dependent on temperature and UDS
gao.1571
1. But i don't understand why it provides a window for various definitions when the constant value is the only choice. it seems it can be a function of variables, such as the static temperature. Can you double-check that?
2. Can you provide the theory basis to implement the marangoni stress for a single phase problem?
