Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Contact problem › Reply To: Contact problem
Andreas Koutras
Is the thickness of the metal sheet shells very small? A small shell thickness can cause the contact to be released before expected. You can try to increase the contact stiffness by setting SOFT=1 in the *CONTACT optional card A, set the scale factors SFS and SMF to a low value (such as 1e-12), and increase the SOFSCL to 0.4. Otherwise, try with the segment-based contact invoked by SOFT=2. Details are available in the LS-DYNA Theory Manual under Section 29.7.
Note that AUTOMATIC contacts account by default for the shell thickness offset.
Contact examples are available here:
https://www.dynaexamples.com/introduction/examples-manual/contact
AK
