Ansys Learning Forum Forums Installation and Licensing Ansys Products Mesh on Setup Parallel Fluent Reply To: Mesh on Setup Parallel Fluent
You've also not shared topology so the boundary between the two volumes is non-conformal. That may make the set up and display a little more complicated than necessary.
