Ansys Learning Forum › Forums › Discuss Simulation › Fluids › vorticity in CFD post › Reply To: vorticity in CFD post
Luca Capitelli
Thank you very much! I follow the steps, now the vorticity appears but my result is strange because the turbulence is not as it should be for Re = 10000. This is the result after 277 seconds. Could it depend on the solution method? I used simple one with default options and simplec with all options at the second order.
