Ansys Learning Forum Forums Discuss Simulation Preprocessing How do i name internal surface of the object Reply To: How do i name internal surface of the object
It should work, to confirm, you did switch the pick option from volume to surface? You can either hide faces or when you pick a face with faces behind it look for a "layers" icon in the bottom left of the graphics window.
