Ansys Learning Forum Forums Discuss Simulation Photonics Negative waveguide loss Reply To: Negative waveguide loss
Guilin Sun
This is numerical error due to discretization. You may increase the simulation span along the bending direction. You can also correct this negative loss by allowing mode propagating in the negative direction, eg, real(neff) is negative. In most cases it is ok to have the fake "gain" as you know it is due to error.
