Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Segmentation fault and corrupted double linked list in UDF › Reply To: Segmentation fault and corrupted double linked list in UDF
DrAmine
Is it the same case and same UDF you are trying to compile under Windows and Linux? If yes: please check with IT / System Adminstrator.
Please share screenshots of Fluent Console when you compile under Linux and running: perhaps there is something written which might help debugging the issue.
